I intended to make, what I would call a Carbon Fibre skin for a door mirror, purley for cosmetic reasons.
I used your basic hand lay up for the mould and the plug. I was shocked to find the plug, which was three layers of light, chopped strand, fibre glass would not slide over the original mirror, as it was exactly the same size as the original mirror (Doh!!).
Is there a technique for making the mould a bit bigger so that the plug and/or the finished item fits over the part it was made for, or am I stuck?
I accidently dropped both the mirrors, they fell about 4ft, the clear gel coat cracked, I wouldnt have expected this,why did it happen??
Does Carbon Fibre shrink in the same way Kevlar does through the mould/plug process?
