Hi there have been reading over this great site over the last few days as i wanted to get clear in my head what to ask before talking crap.
I’m new to the whole process of fiberglass and carbon parts but was hoping that i would be able to get some guidance on methods so that i buy the correct products etc…
I’m based in the uk and have seen the list people have produced for suppliers so i will go through those to source what i need.
my plan is to make a carbon air box for my car making use of the limited space and have enough of a cold air feed to supply and also keeping as much hot air out. i was thinking a 2 part and then fixing both halves together once complete. the top part of the air box would have an access panel flush to the top, the filter i thought would mount to a turned aluminum piece bonded in between the 2 sections
i did think whether it would be worth using expanding foam to get the shapes of the cavities i can fit the airbox and feed in but then i would need to remove them and also turn these into plugs to take molds from
i then thought about shaping them from high density foam but am just not sure which is the best method as i would like to make it in the best way possible
any advice/opinions are welcomed to guide me
thanks in advance Stuart
