Hi all,
I’ve been reading up on many of the topics here and on other sites as I want to fabricate some CF parts for my track motorcycle. I’ve some experience of GRP fabrication, but none with molds and complex parts.
Progress so far… I have a few questions which I’ve highlighted at the bottom if anyone is able to advise.
I thought I would start with a small and simple bracket - after all, how hard can it be!!
So the bracket in question - it holds the front brake master cylinder and in this shot is my first attempt at adding modelling clay prior to forming the “MK I” mould!
Obviously, the mould created from this part was way too small and tight to be able to create a suitable CF part. In fact, it was too small and tight to even get the original part out again!!!
So quickly onto the “MK II” mold, this time with bigger flanges
Again, still not big enough! But I cut away some of the exterior mold in an attempt to make the mold useable and give it a try laying up a part. Having cut away part of the mold I thought it was ok for a trial.
The mold finish was ok and as the part wasnt going to be too visible I wasnt spending too much time on the finish, but it did get a light sanding and plenty of coats of polish!
It was good to be able to lay up a part and get some valuable practice and experience. However, the MK II mold was still incorrect as the flange on the very short section of the bracket was not big enough (bottom left hand side of the bracket in the image), the CF wouldnt ‘sit’ in the mold and retain the shape so it started lifting away whilst I tried to lay it up.
I didnt get any pictures of the trial CF part, but the finish on the mold side was very poor. I think that the first wet layer of resin was probably way too thick. I mixed up a very small amount but while I was waiting for it to become tacky it started ‘pooling’ in the corners of the mold. Also, once cured the part was quite tricky to remove from the mold, possibly not enough PVA and too much resin in the first pass.
Anyway, I moved onto the Mk III mold, much bigger flanges this time, particularly around the ‘very short’ section of bracket to hopefully overcome the ‘lifting’ issue in the Mk II mold! (See top right hand of bracket in this image)
I have only just released the original part from this mold and have yet to clean up the mold. I think this one should be better andI will give it a trial in glass fibre before another CF trial.
At the same time as making the Mk III bracket mold, I made a pretty quick “Mk I” rear fender mold using the tooling resin and then overlaying glass fibre and resin. Heres the original part and the formed mold
I’m really pleased with how this mold turned out, even though there are some obvious defects. It was a pretty ‘quick and dirty’ trial for a bigger molding and seems to have worked out pretty well in terms of finish and suitability. The original part came out without any real trouble which was a great relief, but I didnt apply enough glass fibre at a couple of the edge positions, resulting in the tooling mold breaking away when I released the part (see top right and top left of the mold in the image). When I made the glass fibre mold I used lots of pieces of small glass fibre mat which were torn apart rather than cut apart. In the main this approach seems to work very well, but even the smallest of pieces of glass cloth were a bit of a struggle to form around the tight radius edges and corners.
Any tips for this? Have I used the wrong type of glass fibre mat, perhaps its too ‘course’ ??
So to, some questions. The original part has a small fixing hole in the centre which is in the base of a recess - the hole is in the centre of this image
When I formed the mold, this section of the mold is a very thin part and I’m guessing is way too thin to be viable to fabricate by ‘laying in’ with CF. The image of the mold above (the green mold) shows this section as a pinch point in the middle of the mold.
So, some tips/questions:
- for the fender mold how do I achieve a neat finished edge? At the moment the “Mk I” fender mold has very small flanges which if used would require me to trim and finish the exposed/finished edge of the completed part. I’m expecting that if/when I do this, the edge of the finished part will not be so good. This would be a very visible part so ultimately a much better edge finish is required. How do you achieve a better finished edge?
- How is the centre fixing correctly achieved and is it feasible to fabricate using this mold?
- Much of the reading up I’ve done indicates the use of a single piece of CF sheet laid into the mold to achieve the ‘completed’ finish. In the case of my fender is it feasible to use a single piece of CF sheet for the upper more exposed element of the part and then lay small pieces of CF into the tighter sections of the mold to create the complete part. (In this fender, part of the finished item is concealed from view so the finish is not as critical). Ideally though, I’m hoping to perfect my techniques to achieve an overall level of good quality.
Any tips, thoughts or views appreciated as this is all good practice for me.
