Hi guys, so glad I have came across this forum, I’m from Australia and started to play with carbon. I have no previous experience with carbon or fibreglass so going through a massive learning curve. I’m starting off with skinning parts (anything I can get my hands on, timber, spare car interior parts and such) with an overall goal to eventually mould and make parts with vacuum bagging or possibly infusion.
Sorry for the long post!
Here are what products I’m using
fabric - 3k 2x2 twill carbon fibre
resin - west 105 epoxy with a 205 slow hardener (also have 206 “normal” hardener on its way)
Question or issues I have
I’m having the same issue as most people of the carbon not sticking down right, lots of the parts I’m doing I don’t want the cloth around the back so I want to trim it tight to finish at the face or edge of the part. The steps im taking are as follows,
1 - sand my part down with 120 grit wet and dry
2 - Wash part and wash again then wipe down
3 - Tape up all places I don’t want resin to get to and trim excess.
4 - Wipe down again
5 - mix up resin and apply first coat, now this west resin seems rather thin and I’m having some fun learning the stages of curing. I have waited till its “tacky” and i can see my finger print in the resin but don’t get resin (or very little) on my finger
6 - lay my cloth down.
7 - recoat with resin and let part dry over night.
Some things I know I’m doing wrong here!
Mixing my resin a little fast as I’m getting some air bubbles.
Cutting my cloth way over size and having trouble trimming excess once i lay it, I seem to “move” the cloth around a little.
Putting to much resin into the fabric (this seems to be a major cause of fabric lifting from what I have read on this page)
So now to the issues. -
Cloth lifting in step 6, cant exactly work out why here but it seems to lift at edges and corners. I use tape to hold down the cloth on the back side of the part but still have issues in some places of lifting.
Cloth lifting in all the grooves or dips when I apply the resin to wet out the carbon, from reading threads on this site im thinking I should be placing my fabric and rolling it into the tacky resin and leaving that to cure.
Questions I have.
What is the best way or at what stage is the best time to cut the cloth back to be a at the edge of the part. I understand there will be some sanding here, im going to take a guess and say it would be after the first base layer of resin has hardened.
With skinning complex shapes is it worth vac bagging the part to get a tight fit in all the dips, groves and corners or edges? the set up seems a little tricky but also looks to give better adhesion to the original part (cloth will not lift). This will give lines and creases but will that only be in the resin?
I had a “ok” finish on one of my parts, it was basic but I was unable to keep the fabric down on some edges and grooves. it was a pain to cut with 3 layers of resin that I mostly rubbed back anyway so looking to refine my process to limit the time that I have wasted doing extra work.
thanks for taking the time to read this and I am so happy I found this site, loads of great information.
