I’m currently using Frekote FMS sealer and WOLO semi permanent release agent now with absolutely no issues. I received a post card from Releasomers the other day and it was saying you can contact them for a free sample of their new release agents. Since I’m always looking for something better and cheaper to use, I filled out the online form. I received an email to contact them via phone and after a brief discussion of my processes, Bill was very happy to send me out a gallon of release agent and a quart of their mold sealer. I will be trying this stuff out this weekend on a brand new plug.
It seems very similar to Frekote’s application instructions…
Releasomers G471 Release:
*G471 can be applied by spray, brush, or wipe.
*If a wax or silicone based release agent has been used previously, remove all traces of previous product using a solvent based cleaner.
*For better results apply two (2) coats – a thin wet film is fine.
*Allow 5 minutes between coats.
*Let cure for a minimum of 10 minutes at room temperature - 5 minutes at 250°F or above.
*Reapply G471 as needed – allow a few minutes to cure, and continue molding.
Releasomers G491 Sealer:
*Apply 1 coat; wait 1 – 5 minutes, or right after the product flashes off, and then lightly wipe/buff off.
*Cure for 20 – 30 minutes.
*Apply 2nd coat if needed following same procedure.
*Like most sealers, best results with a 24 hour cure, but not needed unless your shop calls for that.
He sent me the MSDS sheets as well. Send me a PM with email address if you want the sheets. Hopefully this new release agent works as well or better than the stuff I am currently using. The price is unreal… $66.50 per gallon shipped. That’s pretty dang cheap in my book!
Will post my results next week.
Here is the website if anybody is interested.
http://www.releasomers.com/
