great material but for using as a base for plugs!
i found a box of fake wood floor planks,we call it lino,self adhesive on one side,slightly flexible and easy to cut/drill.my plugs had studs on the rear so i just poked these thru the board,the adhesive is very strong but with the studs it helped the board to bend to the slight curves n the plug then i just stuck alu tape over any exposed adhesive and clayed up the gaps,very easy!
