This is only my second project using any kind of composites so bear with my lack of knowledge if you can.
I was given a gallon or so of epoxy resin and hardener by a friend a while back, I wanted to know what it was used for, did some looking around, and got hooked on the idea of building my own bike with carbon fiber.
I have settled on the Idea that I want to build a recumbent trike. So far I have tidbits of info on the process from various different sites, people, and articles. I will link to what I have been looking at at the bottom. I am using the build plans located here
http://www.atomiczombie.com/Warrior%20Recumbent%20Tadpole%20Racing%20Trike.aspx
that are meant to be used with welded box aluminum in stead of CF as a guide for building the hardware. Obviously the carbon frame would be a little more filled out than the spindly metal frame is in the pictures.
I have chosen lamination over any kind of infusion or vacuum process simply because it seems like a ton more work and money. I am planning on laminating fiberglass and then CF fabric over a foam form and the aluminum hardware to create the frame, similar to the way it is done in the instructable link at the bottom.
the epoxy resin and hardener I am using are proset 125 resin and proset 226 hardener, if that is of any importance.
My main questions are:
How thick of a laminate would be needed for it to be structurally sound? (150lb person)
I know the resin is “able” to bond metal but how well typically does a resin like this bond between the Carbon fiber/Fiber glass and the aluminum?
At this point feel free to give advice, criticism, warning, whatever. Hey, dismantle my whole idea if you don’t think I should try to do this without some kind of formal training or something. Just let me know.
Thanks in advance for any feedback!
-Nathan
Relevant links
http://www.instructables.com/id/How-I-built-a-carbon-bike-frame-at-home-and-a-bam/?ALLSTEPS
http://www.manytracks.com/Recumbent/Poste.HTM
http://www.utahtrikes.com/uploads/utpix/382/picture/sideview.jpg
