ok, so my school team and I tried our first infusion part today and we had quite a few issues. I know threads like this are kind of useless without pictures, but i’ll try to explain the best i can and I’ll have pictures later, they are on my team mates camera.
So we’re just trying to make a flat plate. We had a piece of (waxed)glass for our base with two plies of uni-directional carbon on top of that (0-90 orientation). On top of that we had our peal ply, followed by the breather fabric, and all topped with some painters plastic for the bagging material. We are getting some actual bagging material from our sponsor, but for our test we figured it would work for now…we may have been mistaken. The bagging material was held to the glass with some gray putty tape. All was hooked up and pulling 26"-27" of Hg. My pump does have a minor leak so it cannot be shut off and have the system hold vacuum. I’m buying a check valve for the exhaust so that should fix it, but I don’t think that was our problem.
Any ways, we started the infusion using this resin (pt2712) with the part B hardener. the resin was measured by weight using a precision scale, but it did not cure. It’s suppose to have a 70 min pot life, but after about 90 min, it was the same consistency as when we first mixed it. The resin is left over and has been sitting on a shelf for about a year. I don’t know a whole lot more than that. So can epoxy “go bad” from sitting around or are there any other reasons that could cause resin to not cure? FYI, It was also being done at room temperature.
Back to the infusion itself. it started well but after about 2" into the infusion it just slowed to a crawl, and took maybe 30 min to travel another 6". So being impatient I decided to try and “help” the resin along which resulted in a hole in the plastic. I tapped up the bag and was still pulling 26" Hg, but resin started pooling around the inlet tube and was not infusing anymore. Does anyone have any idea how I could be pulling full vacuum but not getting infusion anymore and why the infusion slowed down so much?
I’ll try and get pics of the system soon, but if you need anymore specs on our set-up i’ll be happy to describe anything. Thanks for the help guys!
