I haven’t been on these boards much. I got out of the composites world several years ago. I sold off all my resins, vacuum pumps and miscellaneous hardware.
I kept my 300+yards of 5harness Carbon Fiber though…
I want to overlay some Carbon Fiber ontop of some 2x4 piece of wood. These wood piece will go into the truck bed of my hot rod 1938 Ford Pickup. I have never wrapped wood so I have some questions:
What type of wood should I buy? Pressure Treated or not? Is plain jane cheap wood acceptable?
How should I prepare the wood surface? Seal it? If so, with what? Sand it? What grit?
What type of resin should I use? I want to avoid epoxy resin if I can.
How should I wrap the wood with the Carbon Fiber? Single flat piece only on top? A piece that lays on top but wraps down both sides? A single piece that wraps compeltely around the 2x4?
The current wood in the bed is some low grade stuff that was painted black. On really hot days the sap from inside the wood seeps out. I think I will have to pull it out and completely replace it with new wood.
The epoxy resin I use to use for my products was always a pain to get the mix ratio perfect. I scrapped so many parts because I didn’t weigh thigns accurately.
I don’t want to spend a ton of extra money to get this project completed. So, if I can use the current wood I have and simply sand it and fill in the knots and broken spots with wood filler, that would be cool.
Thoughts and advice?
