First Guys, thanks for any help you give. I’m new to spraying and new to this board
I have a Hot Tub shell (fiber glass with gel coat) Im converting to an out door above ground spa. I’m removing all the jets and putting in a water fall.
Part one of my Project
Im using http://www.evercoat.com/productDetail.aspx?pID=106 and block the holes by,
taping wax paper on the inside of the tub<<<<< is wax paper ok to use so gel coat wont stick?
then putting piece of Styrofoam over the wax paper to hold it in place
Then for the back side I will use the evercoat tinted according and mix right and brush it on the same thickness as the original get coat 3/32 approx 2.38 mm [COLOR=Red]<<<<<can i brush this on to 2.38 mm or do half that, let it dry, then sand (200 grit) then apply second coat, if so how long should it dry in be[/COLOR]tween coats.
[COLOR=Black]After the gel coat is applied I will then sand and do my layers of fiberglass to the same thickness of the tub ( 1/4 inch ) [COLOR=Red]<<<<< again do I sand the gel coat with 200 to to apply resin before matting.
[COLOR=Black]Thanks again for all you help and suggestions
Dave
[/COLOR][/COLOR][/COLOR]
