I have been working with a closed mold design, using two split mold halves and a internal bladder. The part is going to full production shortly, but the bladder is the weak link. Currently, the part is hand laid followed by placing a bladder in one side of the mold, mold halves are bolted together, and the bladder then pressurized. Results have been improving, especially after placing intensifiers in some of the more detailed areas the bladder couldn’t apply sufficient pressure.
The bladders have been fused together using Strethelon 800 which seems to work fairly well, but it is time consuming. The bladders often fail or can be difficult to remove, or they get damaged during removal. The goal is to construct a bladder that will alleviate the need to use intensifiers, can be reused, so it needs to be tear resistant and hold up to the epoxy resin. I have been looking at the Dragon Skin line of silicone rubbers, which can be brushed on http://www.smooth-on.com/Silicone-Rubber-an/c2_1115_1129/index.html. Should I be looking at silicone, or urethane rubber? I have attempted to make a bladder using shore 60 urethane, but the tear strength just doesn’t seem to be there.
no problem.
