I’m new in fiber jobs, I did my research on youtube and other sources.
I’m planning to build a housing for a 18" axial fan with glass & basalt fiber.
(Picture of the housing, see attachment.)
What I already purchased:
-Protect ointment for hands
-disposable Nitril gloves
-protective mask for aerosol
-protective mask for dust
-safety goggles
-2k polyester mastic
-Axel Paste-WIZ HC (Paste mold release agent)
-1Kg Epoxy Resin (Only in German, https://shop.swiss-composite.ch/shop/resources/downloads/t-Epoxydharz-Typ-L-mit-Haerter-d.pdf)
-Scissors with small teeths
-Roller
-a small room with an electric heater.
-2 layers glassfiber twill 390gr/m2 (14oz)
-1 layers (inside and outside) basaltfiber twill 220gr/m2 (8oz)
I need to build first a two-part mold with polystyrene.
Now the Steps…?
-polyester mastic and grind.
-5 layers paste mold, let it dry four a couple of hours
-mixing the epoxy resin (Is there any rule, how much I need?)
-the first coat resin with a brush on the howle mold
-put first layer fiberglass on the mold and apply resin with brusch
-starting at the cylindrical part with the roller an then to both cone parts
-apply resin with brush
-second layer glass
-roller
-let it dry for 24h @ 25°C
-remove the mold
-grind gently both sides
-put basaltfiber on the mold
-roller
-remove borders
Any suggestions or advice would be much appreciated!
