First of all… I’ll get a real pic of the part later. second, thanks in advance…
now then… here is a side view of a part the we may be consigned to do. it’s 5’ X 5’ and about 8 inches thick at thickest and maybe 1 inch at the edges. it has to support 20,000 lbs total gross what ever. I don’t think there is a shear strength requirement nor an impact resistance requirement. it will be used to cover xfer boxes for local power grids. the thought is what if a semi parks on it, or a car wrecks and some how goes airborne and falls right on it kind of thing to give you about the same idea of what it has to withstand that i have as of now. I’m thinking about 15 layers of 1.5oz mat on top and bottom, with a honey comb or some type of foam as a core. we will be using PER (recomendations welcomed) resin, and to start out with hand layup until it becomes more advantageous to make a (i’m thinking) VIP process for it. I’d rather do it the best way, although the only requirements we have so far are cosmetic appearance and strength. i’m also thinking about resin waste from hand layup and structural weakness from too much resin.
the plan so far to get us started with the part is… mold inside and outside, with a flange 6-8 inches larger than the sides of the lid. placed every 6 inches, bolts with spacing sleeves to ensure proper thickness (and for compression of parts.) I’m not quite sure yet how to cut something that big, because we don’t have the tools for an object that big, but i’m thinking something along the lines of a bandsaw and to smooth out the edges a 12"X6" handheld band sander. something like that. and then some type of non slip covering is require for the outside of the part.
so questions are:
1 how do i figure stress in parts for composites.
2 who do i contact for a custom sized foam core.
3 what resin should i use.
3.5 can infustion be used for up to a 1/2 inch thick laminate OR
3.51 what would be the best way
4 how should i cut the parts when the come out of the mold.
5 and any recomendations for a nonslip coating that will stick to the resin chosen
kind of long, but all input is welcomed.
