Alright, so I’m new to the sight and I am a novice with composite parts fabrication. I hope to gain a little more information and knowledge before D-day when I take the grand worth of materials I have purchased and either mess it all up, or put it all together.
I am a helicopter mechanic in the USMC and most glass work I do is patches and repairs, although I have been in the books so to speak, trying to learn as much as I can to produce this Stand Up Paddleboard. There are other surfboard forums I have researched, but they don’t seem to really grasp certain things I want to incorporate into my board. So here is my process;
The core will be EPS pre shaped and essentially ready to glass at 11’ long 30" wide and 4"1/4 thick. I want to do 2 layers of fiberglass on top 1 on bottom (3.4 oz S glass satin weave), 1 layer of carbon fiber on top of that (5oz plain weave 3k), after that I want to try and sandwich some 2mm coremat soft core material before one layer of a twill weave 3k CF/Kevlar hybrid. My theory with the soft core is that it will help with impacts in between the carbon fiber and CF/Kevlar. I will be using a UV resistant epoxy resin with additive F for aid in sanding and I have just heard it is good stuff so.
NOTE: I am not exactly sure if this soft core material will actually aid in impacts. Since my rolls of material are 50" wide. I was going to take 12" or so from the sides and do a couple of miniatures to see how the turn out will be. Beat them up with a hammer and feel out which lay up is best. I inserted a pic of the soft core stuff.
The tricky part is going to be vacuum bagging the whole thing. I want to try and get it bagged in one go. Top and bottom. All layers. I am of course not sure if this will even work. Nobody in the surf board world I know has seemed to perfected it and I am not sure how the soft core will work in the bagging process. Either way here is what I plan and your warnings cautions and advisories would be great.
I have a 7.5 CFM pump. I THINK it should work. With some slow curing epoxy I think I can lay up the bottom in 30 min before it hardens in the mixing bucket. And then the top with another batch. Any way. Lay up the bottom as described previously. Lay down the peel ply, bleeder, and film. Some how flip it over and as one person is laying the tacky tape on the bottom halves film, I’ll start laying the top of the board I want the lap of material to lap on the rails of the board in the center. Work the epoxy in same as bottom with squeegees and rollers. Lay the the peel ply bleeder and film. I have two bag connectors I was going to do one at the top right Conner and another at the bottom left. I have hose splitter and 25 ft of hose.
I would love for this method to work but I realize it will be tricky to say the least. I know I might have to do one half first then the other. I don’t know if the tacky tape will work well enough on the bottom of the polystyrene blank. I am also worried the the suction of the pump will damage the eps foam.
I want to finish with uni directional CF tape running around the rails of the entire board, essentially hiding the lap line and enforcing the rails from damage.
Any way that is the just of it. Please go easy on me. I would really like to not learn by error on this one since error in this world=money. However I am going to go for it and I do understand the price of this is a bit ridiculous.
Few questions I have
Is 2 layers of fiberglass 1 layer of CF and one layer of CF Kevlar enough for let’s say a 200lb man standing on it all day. Or will it be too much
Has any one had any experience with this soft core material. I got it from elite motoring on eBay. My goal is to increase impact resistance.
I seem to feel like I’ll have to bag the fiber glass layers and the CF. Let it cure then add the SC mat and Cf Kev. Does anyone know if it’ll work the way I described.
Thanks If you actually read that whole post
