So I’ve been wondering on some plug making techniques… Most of my stuff is done by infusion and the thickness of the part is negligible for them to fit perfectly. Now, I was thinking, if I had something I could make a direct mold out of BUT the part needed to be like 1/4"-1/2" thick, how would you do it?
For sake of an example, Lets say I had a bowl that I wanted to use as the plug to make the mold from, BUT the part I wanted to pull out from the mold needed to be 1/4"-1/2" thick what is the fastest and more accurate way?
This is all I could think of…
Option 1: Lay up FG in the bowl, and sand/bondo til 1/4"-1/2" thick.
Downfall, laborious, and likeness it will not be uniformly even
Option 2: Try to Vacuum for a piece of plastic to the bowl using a 1/4"-1/2" sheet of poly polypropylene (or laminating several layers to create the thickness I want to achieve
Option 3:…?
