When ever I do an infusion I either coat the mold with Duratech top coat, or I Duratech top coat the part after demold and trim. I always use Duratech top coat because it eliminates any tiny pin holes, (if any) and makes clear caoting a breeze.
From my experience never clear coat anything over 800 grit. Anything higher and the sand scratches aren’t coarse enough to grab the clear coat well. You can get easier delamination. Thats just my experience and what I’ve been told / discussing with colleagues over the past 7 years.
I personally clear coat over 600 or 400 sometimes. I also use a high build high solid’s clear coat, (2:1) so I don’t have to worry about seeing the sand scratches through the clear coat.
I also use either PPG DC3000 or the top of the line PPG, (I forgot the name) so I get very little shrinkage.
However, if I use the DC3000, (speed clear) I make sure I sand to 600 because the ultra fast clear will have more shrink than the 18 hour cure clear. Same applies for force curing.
To clean the parts I usually power wash first or wash with Acetone. After power washing and drying, or acetone wash, I wipe the parts down with Naptha, prep-all, or denatured alcohol. Urethane reducer works also if you have it and you are in a pinch.
Acetone and Lacquer thinner leaves a very thin film on the parts I hear.
John
