I’m building a prototype with a set of leaf springs for a piece of sporting equipment.
My design:
Each “leaf” will be about 1.5" wide, 12" long, and about .040" thick (I’ve been using three layers of 9oz. uni-directional CF for each leaf). The spring itself will have around 7 leafs and will be roughly semi-circular in shape. Each spring will have a working load of 30 to 40 lbs.
My questions:
Can someone recommend an epoxy system for this design?
Given this is a piece of sporting equipment, the springs will see a range of temperatures from baking hot to freezing cold.
I used Huntsman Araldrite GY 6010 in my first attempt. I left a part in the sun for a little bit and it went totally soft. I’m a newbie and didn’t know anything about Tg until reading some threads in this forum this morning.
Can a kitchen oven be used for curing small parts without any unfavorable consequences?
I don’t have an oven (other than the one in the kitchen) but could build a simple one one if need be. Curing at RT would be ideal…if possible.
Can someone recommend a uni-directional CF to use for this design?
I’ve used two different 9 oz fabrics so far. The 1st was woven (over and under) a thin piece of (plastic?) thread. This proved to be weak where the CF lapped the thread.
The 2nd was bonded to a thin piece of (hot melt plastic?) thread on one side of the fabric. I experienced a lot of loose fibers on the side that wasn’t bonded to the thread. It was difficult to spread epoxy on this side without disturbing the lay of fiber.
I’m thinking “sewn” fabric may be the way to go…or pre-preg without any binder other than the epoxy. Any thoughts?
