hi i just had some quick questions from you guys. im currently covering my car trunk in cf and need some advice. i applied two thin coats but the resin looks to be uneven. do i keep adding more layers and THEN sand it down to make it even? if i sand in between the layers what grit should i use? anyhelp will be appreciated.
also, where can i find 1500 grit sandpaper i cant seem to find any locally.
