Hey guys,
So I’ve finally solved my problem and can now make perfect parts. My problem I’m having now is drilling the holes in the carbon fiber, I drilled an initial pilot hole and it went fine. When I used the larger bit, it bound for a second a ripped right through it. So basically it took small chunks of the epoxy out with it. You can clearly see the area around the holes that got damaged. Especially in the middle bottom hole.
How do you guys drill your holes so that the surround area of the part does not get damaged?
Thanks a bunch!
use a smaller drill ( undersize ), then dremel grind the hole to correct size. back up your part with a sacrificial piece of wood.
