Hi Guys,
Fastrr put me on to this forum after finding me somewhat alone at the FibreGlast forum, many thanks to him.
I’ve a motorbike, and I thought it would be nice to make some carbon fibre parts for it, some cosmetic, and one minor structural unit (a battery box).
I’ve got as far as completing some molds, they’re made from VER, CSM, and a white gel coat, all vac bagged together. They’ve come out pretty good, so I’m ready for the next steps.
Funnily enough, the methods I’ve used so far are similar to what John Britten used to build bits for his bikes! It’s funny because I live in the same city as he did! (Christchurch, NZ) A 50 degree oven (a friend built it for me from 60mm polystyrene, a 25W light bulb keeps it at about 48-50 degrees C), VER, laid up and vacuum bagged.
What I’ve got available to me is:
92gm plain weave (2.7 oz/sqf)
198gm plain weave (5.8 oz/sqf)
155gm twill weave (4.6 oz/sqf)
196gm plain weave (5.8 oz/sqf)
Ideally I would like all my parts to look that same. The side covers have some tight (5mm radius) corners on them, which is why I had to end up vacuum bagging the molds (but the experience gained was worth the effort imho). For this reason, I’m thinking that the lightest sheet I can get would be better, and that I’ll make the side covers entirely from 92gm.
Questions:
If I use 92gm plain weave for the external surfaces (to keep them all looking the same) for parts that I would like to be stronger (like the chain guard), is there any reason why the inner layers can’t be 155 or 196 twill? Will they all laminate together ok?
Is twill typically cheaper than plain weave, as it is from my supplier (just a curiosity thing)
Considering that I’m an amateur hobbyist, laying up my weave by hand, is there a best technique for ensuring that the weave is adequately saturated with resin before laying it into the mold?
Can I use a typical automotive clear coat for finishing my parts?
I saw on a video on Google Video a man who did an overlay, which then he essentially poured resin over afterwards, to get a gloss effect all over. This seems wasteful?
I have laid up and cured a small piece of carbon tape as an experiment, the effect was quite nice (with the stunning 3D effect that I am working towards), and with clear coat would look better still. If that quality of finish is acceptable to me (I’m a realist), is there any reason why I can’t just run with that?
The pump I have is about 150 litres per minute. The documentation I got from the composite supply store mentioned using a pump approximately 150 litres per hour… that would make mine about 60 times too powerful! It seemed to work well enough (it’ an old pump from a friend who is a refrigeration technician), but I’m concerned that perhaps it could suck too well, removing too much resin from the mold. Is that a valid concern? Can I have too much vacuum?
For my relatively small purposes, is there any reason why I would want to choose a twill over a weave, assuming that the ‘look’ wasn’t the most important thing to me? Ease of use is probably as important, especially performance around small curves.
No matter, I’ll figure it out
