Hello everyone,
I am a research student working on natural (jute) fiber composites and was hoping for some advice/assistance with the vacuum infusion process. I have run several trial castings with the following parameters:
-6 layers woven jute fabric (0/90)
-Fiberglast 2000/2120 series epoxy (de-gassed in vacuum chamber)
-Enkafusion nylon flow media
My layup order is as follows:
Glass plate->laminate stack->peel-ply->flow media->spiral tubing connected to resin feed on one side and another spiral tubing connected to vacuum line on other side->bagging film
I have infused at -30in Hg, -25in Hg, and -20in Hg, and in each case I am left with air pockets in the final casting as shown in the attached pictures.
In one case I was able to make a part with no air pockets, but the fiber volume fraction was very low (~28%)
For my most recent failed casting, this was my procedure:
-Set up lay up as described above
-slowly draw vacuum to -20in Hg
-check for leaks
-De-gas resin in vacuum chamber
-unclamp resin inlet tube to start infusion
-at ~2/3 of the way through infusion clamp resin inlet
-after allowing sufficient time for infusion to finish and resin to gel/cure, clamp vacuum tube and shut off pump
In this case the infusion itself too about an hour and the vacuum was left running for an additional 2 hours before clamping.
Can anyone offer any advice on how to improve my composites? I’d really appreciate any help
Images can be found here: http://s192.photobucket.com/albums/z67/MikePinto_photo/Natural%20Fiber%20Composites/
