Today, I wanted to make an integrity test over a little crack I have in one mold wich did not look very suspicious, I made a small square bag that could cover the crack sealed and pulled vacuum, much to my surprise, my brand new Greisinger GDH 200 14 showed a very small drop, it took 3-4 minutes to show the next number in the absolute pressure reading, after trying to improve the seal of the small square bag, just to get the same pressure drops, I isolated with two very reliable clamps the piece of vacuum tube that only contained a T connector and the gresinger gauge, and much to my surprise, it showed the same very small vacuum drop proving in my opinion that the gauge itself was the cause of the leak
Can this be possible, that the absolute pressure gauge produces (or needs it do its job) a small leak ???
I repeated the experiment with the gauge connected straight to a tube going to the vacuum pump and after vacuum pulled, clamped the tube 2 meters away from the gauge leaving then just the gauge with two meters of tube under vacuum and again got the same results, so it has to be the gauge …
I was expecting off course, the gauge to show almost unlimited vacuum retention for a long while in such an absolutely simple set up.
Has anyone else seen this happening, it would certainly suprise me for this to be normal behaviour of the gauge …
Or have you closed them to hard that you damaged te hose?
oops… great value…
