I have been trying for a while now to complete an infusion with a perfect part, but have had all sorts of issues. Its been a real learning experience. I have gotten a lot of help so far and wanted to post my latest adventure and hopefully get some more assistance. My initial plan was to infuse two molds at one time.
I have tried to document everything with pictures and videos. I will post pictures of the finished part tomorrow. Fingers crossed.
First I waxed both molds.
My plan was to try and envelope bag the parts because I have had such a hard time getting a perfect vacuum on my molds. I went through and covered both molds with material to ensure no sharp edges damaged the vacuum bagging.
I then made both vacuum bags.
I then put two layers of PVA on the molds and laid the material. I put 3 layers of carbon fiber on each mold, then peel ply, then breather material. I put a small probe in the center of each part where I will attach the resin inlet tube.
I decided to try and wrap a vacuum tube around the entire part. I added small holes to the tubing and then attached to each mold.
I bagged both molds and then attached the vacuum lines.
This is where I ran into my first issue. The first mold started cracking and falling in on itself. I had to abort the infusion as the mold was basically destroyed by the vacuum.
