Hey all I’m in the works of developing my own Engine bay cover for a RX-7. I’d like to share with the community and track my journey. I’ve done a few Fiberglas projects using the wet layup method and can be seen here:
http://muibubbles-design.com/index.php?/juxor-v10/
^^ School project chair I designed and built.
Other FG projects on the site include, sub enclosures, and a 1/2 scale rear diffuser
For this project I will be using vacuum infusion and this is my first infusion part. any tips, suggestions or comments along the way is greatly appreciated!
So to start, these are a few inspirational pieces.
Panspeed
Knight sports
So lets get started!
Building the piece from scratch…
I did some rough mock ups with chipboard to get a rough template. It was too flimsy so I transferred it onto some scrap wood. it was still flimsy and heavy so i transferred it over to a FG sheet i laid up.
Next I began masking the engine bay off. (I know, I should have taped it up more but I got lazy, I will regret it later when i redo the engine bay)
The sheet i made was still a little too thin so I added a layer of the biaxial stuff. super thick
Test fitting and trimming the cut outs
laid up FG along the edges- this gives it dimension in another axis to help rigidity and ensures it tucks on the firewall nicely.
Things that need to be added
-All the straight lines need to meet back at the strut towers, this will complete the gap.
- the cut out for the engine, needs a lip facing downwards.
This leaves me to where I’m at now. If you take a close look the right side sits 1/8"-1/4" lower then the left side, its driving me NUTS. I am designing this with the intention to duplicate and sell them. I want it to be FLAWLESS. Also since I didnt anchor/secure the “sheet” well, its not flat on the right side as well. So, I am thinking of cutting this one up to a flat sheet and transferring it to a 1/2" or 3/4" thick piece of MDF. This way I can use the thickness of the wood to created the bottom lip of the plug. Also this will give me a VERY good starting point as the mdf will be smooth an straight already. Or should i just cut the flanges off this piece and do it the same way but add a lip/flage for the fiberglass “sheet” to sit on ensuring it’s straight?
Thanks!
