Hi everyone, i’m having a go at making this ducktail style boot spoiler, i used laser cut 2mm hardboard templates to create the pattern.
i spaced out the templates on the boot lid (trunk lid) at 50mm intervals with PU foam blocks hot glued in-between, trimmed and sanded the foam down to the templates, skimmed with body filler and brushed on a primer pattern coat,
so here’s where i am at the moment, sanding the plug smooth.
comments are welcome!
