Hi Guys
I have been building some drones by myself, mostly 3d printing and aluminium and CF sheets.
I want to take a step further and try a molded carbon fiber multirotor.
There are 3 main criteria:
- It should look good
2)It should be light in weight - It should be strong and reliable
I am trying to figure out what GSM and 3k,6k,12k mean in terms of engineering.
I know GSM means grams per sq meter and 3k means each tow would have about 3000 fibers
In terms of strength and weight how different are they?
For example:
10 layers of 6k plain weave 400 gms vs 5 layers of 6k plain weave 800gm (Made up numbers)
If both are oriented similarly, will they have the same strength
Most importantly will they have same packing efficiency, ie will they require same resin under similar manufacturing method (example vacuum bagging of the same shape)
Similarly:
3k 200gsm be the same as 6k 200 gsm in terms of strength and weight (resin requirement)
Any idea what type of fabric should I start with?
I plan to vacuum bag. I have also found someone with years of experience in Glass fiber moulding. I guess my moulds will be sorted (and split mould friendly design).
