I’m planning on fabricating a CF airbox for my track bike. I’ve picked up a spare original part from which I hope to form a mold (or series of molds) from which I can ultimately fabricate a composite part.
The original part is a 2 piece plastic airbox comprising lid and main body.
I’ve been staring at it for months trying to decide the best approach and before I start cutting up the original part to prepare molds I thought I’d seek any views.
The ultimate CF composite part need not be too pretty as it will be hidden below the tank on the bike. That said, a reasonable finish would be preferred.
Heres the original part assembled…
and here it is with the lid off
The lid will be made as one mold, the base is the tricky part I’m planning to make in 4 (or more) separate molds and then resin together.
So, comments please on the proposed mold ‘pieces’ I envisage as follows:
I will carefully cut off the 2 x air ducts that are the oval pieces exiting the main assembly on the top left and bottom left of this picture. I propose to fabricate each of these as separate composite pieces (each piece in a 2 part mold) which will later be fitted (using resin bond) back into the final assembly. Longer pieces will be made as I envisage the oval tube to protrude inside the finished assembly so that there is good overlap to resin bond, with any final material trimmed back inside the finished part to suit.
Next piece; I plan to remove the ‘ribbed’ section of ‘tray’ shown in the photo above and in the photo below. Again, I envisage forming a new composite ‘tray’ with large overlaps so that it can be dropped into the final piece and resin bonded in place. Again trimming back any surplus material. Heres the ‘tray’ piece viewed from inside the airbox and also showing the 2 x oval ducts which will be fabricated separately.
That should leave me with one final piece which is a reasonably straightforward (!) larger main body into which the above component parts can be fitted once prepared.
I’m about to start cutting up the original piece and wanted to get some feedback before doing so!!
I’ve also got to cut off a number of small protrusions for breather hoses and the like. I envisage these can be added into the final part at the end of the process using soem pre formed CF tube or similar.
Last question, flanges? Not flanges on the mold, but flanges between the top and bottom final pieces. As you may see from the above images the original part uses a raised profile in the bottom piece around the edge, and a ‘slot’ in the lid piece around the edge. One ‘slots’ into the other to achieve a seal once the airbox is together. I’m not sure how to achieve an alternative method for this, other than to form a rolled edge thatreturns inside the finished part to form a wider flat edge on both top and bottom parts, which can then be gasketed together during final assembly.
Any thoughts or tips???
PS -just thought I’d add that my latest thoughts are to form a male mold, since I want the smooth finish on the inside of sirbox for maximum airflow, thus the ‘raw’ carbon finish on the outside. This will probably simplify slightly some of the molding process; particularly the oval air intakes
Complicated.
