EDIT
The MTI valve is our new product. It will make the infusion process more reproducable. It is mounted in the resin feed line
with the direction shown on the MTI valve.
I recomment to seal the hose on the MTI valve with tacky tape, sometimes with hard tubes it might not be 100% tight.
The MTI valve has a spring inside that simulates a conter pressure for the resin. This pressure ist adjusted that you reach a VF of about 50%. Tha VF depends on the kind of fabric used in the layup.
The valve will not guaraty a VF of about 50%, but it will make the process reproducable. In combination with the MTI hose you will get the same in every part. If you make 5 car hoods for example, each of them will have the same VF.
The MTI valve will also prevent resin pooling at the inlet. It allows just as much resin to be infused that is needed to get the adjusted VF. The fabrics will even at the resin inlet not relax totally. They will stay compacted.
This means the infusion will be little slower but more equally.
To show this effect we made a small animation video.
[ame=“http://www.youtube.com/watch?v=8Pk5jNG9SEc”]MTI Valve and how it works - YouTube[/ame]
After the resin has saturated all fabrics the MTI valve shuts it self. You have now a nice self regulating process. You can start the infusion and when its saturated it will stop without oversaturating the part.
After resin has reached the MTI hose I most times clamp the resin feed because in test we sometimes had carbamate or dirt in the resin pot wich did not allow the MTI valve to close completely and so it might happen that some resin can travel in the part after infusion is completed and the MTI valve has shut.
If you have questions or like to get a sample just contact me.
You can find your Dealer on our homepage www.dd-compound.com
