Hi All,
I have just started a new bike project (KTM 380 EXC supermoto build) and have been thinking about making some simple carbon fibre parts, mainly just the bodywork.
But I got to thinking about other parts that I need, then I wondered if it would be possible to use composites for the side stand? I am interested in giving it a shot, but I wanted to get some input from those more experienced than myself, because this is a load bearing part, a bit different to body panels that just sit there and look pretty!
The bike weighs around 110kg with fuel, so this is the weight that will be leaning on the stand. The stock stand is known to bend very easily, but I think that is dut to the mounting bolts. I think it’s possible to make the part from composites without the part being too bulky, because it only needs to support the leaning weight of the bike, not the full 110kg.
Here’s a picture of a standard alloy stand to help get the shape & function in mind:
So - what do you think the best way to approach this would be? If it’s even feasible?
I am thinking some kind of core material for added strength & rigidity, and a thick layering around the mounting/hinge points. The other thing that seems kind of tricky to me is that it must be build up the opposite to how something like a body panel is done. For example I can’t see any way you can use a regular mold for a part like this??
But then again I have very limited experience, so I’m hoping that someone can help me learn something!
Cheers
