I’m new here and new to fiberglass. My project is a pair of custom fiberglass saddlebags. To give you a rough idea of the size, they are about 24" long, 15" tall, and 10" deep. They will be bolted through the back wall of the bags to a steel frame on the bike. After looking at how much they would cost to buy (over $1200) I decided to try and make them myself. I figure I’m mechanically inclined with a structural engineering background. So I’m smart enough to pull this off…I would think…lol!! I’ve done a bunch of reading on the net and have learned alot about the process of laying fg, the types of resins and reinforcements, etc. However, I still don’t have a feel for how thick the products end up.
Anyways, from what I have learned, I have created some foam plugs from blue insulating foam from Home Depot, which are almost ready to make my forms. I intend to use polyester resin, so I know I need to protect the foam. I am thinking about taking a thin plastic bag (like a garbage bag), placing the plug into the bag, and then sucking the air out of it with a vaccuum. Will this work? I am aware that I’ll end up with some crease lines from the bag in the form, but since this is a one-time project (hopefully), I’m not too worried about the extra finish work. I’ve also read that using latex house paint would also protect the foam. Would this be a better method? And finally I read that covering the foam in clear plastic packing tape works too. What would you recommend?
Anyways I’ll then create a 2-piece form using 1.5oz fiberglass mat. My question is How many layers should I use? I’ve been told it should be at least 1/4" thick. But I have no idea how many layers it takes to get that thickness. I want to order my materials this week, and have no idea how much to order.
After the form is done, I’ll lay up the bags in the forms with pe resin and cloth (probably in the 6 or 8oz range) for strength, with mat to build up thickness. My question here is How many layers of cloth and mat? And what order do I lay them down? I was told at one time that 3 layers of 6oz cloth alone would be good, but then was later told by someone else that that would not be nearly enough. So I am confused.
And finally, my last question is about the gel-coat. Is it really necessary? I am already expecting a fair amount of finish work. And since this is hopefully a one-time project and not for any type of production runs, I am trying to keep the costs down. But if it is necessary, I definitely want to do it.
Thanks for any help. And I am sure I’ll have more questions as I progress along through this project.
