more than 50
Ok this my be a dumb question but how do you make some thing that is more than 50" ??Do you splice the sheets together ?Can you order CF lager than 50" ? say you was to make a 6’x6’ panel .Ok as always thanks for the help
Simplest is an overlap.
60" is available.
I ordered 63" cloth from uscomposites.com
thanks for the reply’s. A pics of a good splice ?
I just made a single piece floor for my van, 4,300 x 1,780mm. It’s made up of four pieces of foam core, glassed on both sides and I just overlapped the glass where it ended & joined another piece… ranging from probably a 30mm to 60mm overlap. Nothing fancy there, just a plain old overlap! It turned out good as well!
