Has anyone applied 2k clear coat on mold surface ?
Is it help to get gloss surface ?
You can do this with the Duratec top coat, works quite well.
Yes. Regularly. The finish is only as good as your mould surface
Has anyone had any experience with spraying 2k urethane clear coat over PVA in mold?
Just wondering if there would be a reaction or fish eyeing.
Thanks!
Actually it lays down the best against pva, no surface tension…
I will definitely try it out, thanks!
if you spray 2K automotive clear urethane in a mold, what resin is compatible to laminate on top of it?
…and in addition to this question how long to wait for cure before laying the carbon and infusing over? How long to wait before a elevated temp cure/post cure?
Trying to get an idea of print thru with non-fully cured 2K auto clears as IMC
no answers?
