Hello. I am getting close to setting up for my first mold. Here is a picture of the plug that I have made.
I have since covered those holes you see in the cover with aluminum. I am in the process of applying filler and sanding. My questions are these:
Can MDF board be used as a Base for Molding? Can Wax be applied to MDF board so the mold will not stick? I am thinking yes, but I am asking also.
This is a cover is a complex shape. Where do you think is a good place to put the infeed resin line and should there be more than one line? Does resin flow around very tight angles, like the point in the top of the cover?
I pretty much have most of the process figured out for molding and infusion. Just from time to time I have questions and need advice. If you all see anything else that could go wrong or needs to be addressed please advise.
