How would you make the inner mold and how would you do the lay up for this part? Make the part in two pieces and then “glue” it together … like make the top , then the bottom lengthwise like they did? Or is there a good economical way to make the part in one piece not using a foam or Aquacore inner mold.
Also since I am thinking of it… what chemical do you use to completely dissolve out styrofoam or urethane foam?
