Sorry, there’s a bit of detail and long winded.
Hi everyone! New to the forum here but have been lurking for about a week or two. I have been doing some research concerning carbon fiber since early/mid december for a project I want to do. Real work got in the way of my time but now I have some time to dedicate to this now! Many, many questions have been answered but it seems there is always something that leaves me wondering or one answer leads to a new question. So time for a question for some you guys who I would daresay are in the category of the elite when it comes to molding and composites.
Unfortunately, I hit a road block in my design until I resolve the whole process so I can design the part to be able to be molded the best.
My background: I worked about a year for a company in which my primary job was to machine large mold patterns for vehicle accessories. Engineers would send me a file, I modified the file to be able to make an accurate mold out of it, and made it on a massive CNC. The material we machined was a Wheat board MDF. We used wheat board because it leaves a fairly hard surface and we needed something that could take 300-350 degree temps during the trial period. We heated plastic, laid it on top and if the company approved the design, we made it into fiberglass molding. Basically we saturated the wood with a wax mold release and it worked perfectly fine for the most part. Now we did make good enough tooling but we never vacuum bagged anything. This was lead to some issues of course but in general things did turn out ok.
Now I want to make something out of Carbon fiber. Sure sounds easy enough I suppose as I have worked with fiberglass plenty of time, but making a higher quality is a bit different. I need to use CF for the reasons CF was made. Structural strength at the lightest possible weight. However, due the nature of what I am making, I will need to make 3-6 different molds before I have a finished design.
Items on hand:
[FONT=Calibri]- [/FONT]CNC router. Good for woods but no metals.
[FONT=Calibri]- [/FONT]An industrial vacuum pump capable of 3.75 CFM and an ultimate pressure of 7.5 X 10 -4 Torr (0.000000987 atmosphere) and a Smaller Gast pump or 2 laying around. 12.7psi is my atmospheric pressure at my altitude.
[FONT=Calibri]- [/FONT]A pressure chamber I can fit the mold in and pressurize to 150ishPSI. It is rated at 385psi but air compressor won’t go that high. It isnt technically an autoclave as it’s just a homemade tube I salvaged from an industrial heat exchanger 10.5” ID x 42” long inside. I am modifying it to have internal access to a vacuum line and return line internally, thermal elements suitable to heat to 300 degree F as well as wiring several thermal sensors I can mount on the wall, and a couple places on the mold to insure proper heating.
Question #1: What type of mold material to use? I will be machining the blank using a CNC router. Wood, foam, phenolic, etc as possible but no metals really. Paying a machinist to do aluminum is costly. Material cost about $350 for the blank and $1200-$1500 in machining costs. Phenolic (plastic composite) is nice but I cant autoclave it as it deforms when it heats up. Wheat board MDF is nice but I am concerned that a vacuum will pull the resins into the wood through any mold release essentially making it solid block of junk. Can I slightly over machine a MDF mold, say 0.100in, coat the mold in a high temp material similar to bondo but something with a better finish, and then re-machine? I know some sanding, buffing and finishing will be in order but I machine tight passes. What do you guys and gals recommend? I do have Ren material on hand but really don’t want to machine it out of this stuff. It isn’t really a good shape me anyways.
Question #2: Initially I considered just doing a wet layup with fiberglass on the 1st mold or 2 to get a feel for the spatial orientation of my design. Unfortunately, I can get close but I am not able to design a final product. 2 to 3 molds to get the general spatial dimensions correct, then fine tuning of structural point could be 1 to 2 more molds. I assume by the 6th mold a quality, useable product can be had. However, some key area of the composite will be in the 0.200 to 0.300in range or roughly 17-26 layers of 3k 2x2 5.7oz fiber. I fear during a wet layup, the resin will begin to cure before I can get the final layers on and a vacuum will not work correctly as some resin will be setting already. I estimate it could easily take 2hours to layup the first few molds, perhaps 3hrs doing wet layup. The sheer number of layers, thickness and shape dictate an infusion type is not possible but this would be a nice way to do this. Can infusion pull through 18 to 27 layers of fabric, do they make a low viscosity high temp epoxy resin?
Question 2.5: How do you lay prepreg up without getting air between the layers or will the autoclave pull the air out? I am considering prepreging my carbon fiber with some high temp stuff and then laying it up.
Question #3: If I were able to a wet layup any apply excess (not extremely excessive but liberal amounts) of an epoxy, if I vacuum bag it them and drop it into the homemade autoclave, will this remove excessive resin? Dry spots are hard to get rid of in my experience not matter how hard you try when doing a wet/painted on lay up. I know this can be an issue for determining correct resin/CF ratio though so likely wont do it.
Question #4: material. CF will be the material but in some areas the mold will be thick. 0.200 to 0.300 as mentioned above. Is a 3k 2x2 5.7oz fiber the best to use? Strength is critical. But I do have some sharp turns and the ability to drape will be very critical. I really don’t want to go smaller as the cost increases and the number of layers I need to make significantly increases. Each mold pattern nests well and I can get the patterns out of about 2.5 to 3 yards x 50” width stock material.
Question #5: Balsa reinforcement, will it suck up resin when vacuumed? How about when pressurized in an autoclave? I have a couple of small areas where I just have to have some internal structure to make a rib of some type for side support. Rib would be about 3/8” x 3/8” x 3.5” long and curved with rounding on the upward facing edge. Perhaps I could make a small 2 piece mold and inject foam into it and use that instead? What type of expansive foam would be good and not compress under autoclave pressures??
Also need a mold release recommendation for a smooth finish, how do the spray releases work? Epoxy recommendations would be appreciated as well. Mold release film type? I think I have all the rest figured out. I could figure all these things out too but there is so many types of resins out there and release waxes and everyone of them claims they are the best brand.
On materials, price matters but in truth I can spend whatever I need to but I may at some point go into production on this and need to keep my repeatable costs of consumables (Everything minus the cost of the fabric) at or under $50ish per unit. I estimate about 10oz resin per part would be used assuming 65% CF/35% resin weight. If in production, I will prepreg my own fabrics. Initially I can spend a few $k’s gearing up but I think I have the expensive pieces in place already.
I appreciate all of you who have some insight and took the time to read this!
