So far I have only used Smooth-On Epoxycoat Red for making molds. I was wondering what others use. Is there a benefit or disadvantage to using epoxy for my molds? It is also about $100 for a gallon of the Epoxycoat Red so I was wondering is there are any cheaper options?
My next question about surface coats is about degassing. Do you degas? I actually tried and the second I pulled a vacuum the cup overflowed and covered the inside of my vacuum chamber. I was wondering if I should just pull some vacuum but only enough to make it foam, or is degassing is not needed. I have noticed that if I sand a mold it uncovers a lot of pin holes which I am guessing are air bubbles.
As always, thanks for your help!
Daniel
