Hi all,
I saw a post from a year or two ago that touched on the subject of closing honeycomb so the inner face can be bonded without dimpling.
I have a similar use case that involves bonding a very thin inner face to honeycomb. The catch is that the part is specific-stiffness critical so the extra weight for materials to close the honeycomb is problematic.
My sandwich application is a small part (2 " X 6" X 50") with curved faces. It’s essentially a bent rectangular tube facricated in two halves. The faces of the tube walls are slightly curved and very thin (0.010") from 100% uni and the wall comb is 0.250" thk. Unfortunately I don’t have the necessary autoclave to use pre-preg and film adhesive so my proposed approach is to use a combination of lower tech methods as follows:
Step 1: Infuse and post cure the outer face in a female mold.
Step 2: Bond the core to the inside of the tooled face.
Step 3: Close the honeycomb’s remaining open/inner side. This is the challenge!
Step 4: Infuse the cut materials for the inner face on a flat surface to optimize resin uptake. Remove materials from bag and lay the wet inner face over the closed honeycomb, re-bag, cure and then and post cure.
So again the challenge is to close the inner face without adding a layer of glass and micro-balloons that will weigh more than the structural face itself.
So far all I have come up with is the idea of filling the h-comb cells with a removable material. Sanding flush with the edges of the h-comb and then protecting it with plastic film so the inner face can laminated, removed and then bonded after the filler has been removed from the comb.
I’m looking for any ideas on how other users may have solved this problem….so thanks in advance for any advice….cheers
