Hi everyone,
I’m planning on making a carbon fiber part which is about 2 metres by 1 metre (6.5 feet by 3.1 feet). This part is mostly flat except for a few curves on one end of the part. It will be of constant thickness (approximetly 6 plies thick).
I was originally planning on doing a wet lay up, however, I have recently come across some very low temp cure prepreg (can be cured at 70 degrees Celcius (160F)). Do you think I would be able to use an MDF mold successfully at this temperature without running into warping or other problems?
My plan was to seal the mold using a Frekote sealer (CS-123), use Duratec gray primer and sanding to achieve a good surface finish and finally apply frekote 710LV as a release agent.
Any feedback is greatly appreciated!
