I made a repair in a specialized bicycle.
The method i used was to wrap the broken area with prepreg material.
I could also use the wet lay up method but i tend to prefer prepreg use when this is possible.
Before i do anything i checked in specialized site and they claim to use prepreg carbon fiber that cures in 150 celsius .
My thinking is if a prepreg is cured at 150 celsius that means it has at least operating temperature of 100 celcius - this is what i need for my prepreg to cure.
What i did is that i put the frame in the oven and started to elevate the temperature from 70 degrees to 75 then to 80 then 85 90 95 100 ,105,110 and stop . Every time i was letting the temp for 20 min and then ''checking - with my own hands - especially the fork section if i could notice any difference in stiffness or the material softening etc.
The idea is that if i would feel any difference in the stiffness of the fork that i could inspect easily because there is some play between the legs i would undrestand that i have gone to the thermal transition temperature zone of the material and i would stop immediately.
I didnt notice even the slightest change in the abilities of the material so i cooked with prepreg at 100 celcius fo 2 hours.
Athough i am very happy with the result a person that i respect told me that i shouldnt use prepreg for doing repairs on existing bikes because i may cause serious damage due to damage heat can cause to the frame.
I would really like your input and concerns on the method i used
