Any one in the state of California know where I can get the matte clear coat? does the matte clear coat sold in Michael’s work for clear the carbon fiber parts? such as this http://www.metropartsmarket.com/craftpaint/krylon-c5s2.html
I would not trust spray cans to give good results.
Pretty sure there are flattening agents one can add to clear coats to dull the shine. What you can also do is just use a release agent that is made to give a matte finish.
Use an HVLP spray gun and air compressor with 2K urethane clear coat. you can buy the matte addative.
sometimes i will clearcoat a really small part with a rattle can but I try to stay away from doing it.
where can I get the matte additive?
I’ve been using Alsa paint’s and additives for a while now with very good results.
ill have to try that! I have a couple customers that want a matte finish and have been looking for a solution
what’s the ratio of clear paint with matte additive? It’s a little expensive just to add additive but if it last for a while then it might be worth it.
BTW I found this http://www.spaceagepaint.com/product_detail.aspx?id_product=2654 will this work too?
sikkens make an off the shelf matte clearcoat
