Hi all!
I´m producing some carbon fiber automotive body panels using infusion.
I´ve been using the uni mould system from easy composites UK that consists in a vinylester gel coat, coupling coat, and poliester resin to back up.
They claim their poliester resin is filled and suitable to use with post cure with temperatures to about 90 degrees. But they don´t give any datasheet on the resin.
Problem is that i´m experiencing some issues with this system beeing:
- gelcoat is not sprayable (or at least i cant find any info were they say it can be done) and i prefer to spray over brush.
- i´m getting voids under the gelcoat no matter how hard i press the fibers
- i´m getting lots of print through on the gelcoat
- it distorts quite a bit and the maximum temperature i use in post cure is 60º
- it´s from UK so price is in Pounds and makes it very expensive to buy since my country has Euros as main currency
Can you recommend a mould making system that is suitable to use with resin infusion and oven post cure?
I would prefer a poliester/fiberglass based one has i only produce maximum 20 parts from a mould and want to keep my costs low on that. But if you use any other option i can also go for it as i prefer to spend all the time at once in the mould and not beeing always repairing/fixing it
Thanks in advance for any help.
