Hi guys,
im building an old school wood boat for fresh water, and would be trailered. 16’ long 6’ beam v8 inboard 2 seater. 1935 garwood speedster design. I am using a cold molded hull building technic. I will use okoume 1088 marine grade plywood 5/32"thick x 6"wide x needed length planks to make up the layers, of which will be layed on opposing 45-degree angles from one another. all the planks will be encapsulated in epoxy such as west systems or other compatible, and also bonded to each other with epoxy. To this i would like to add interlaminate layers of composite for strenght and long life. I have come up with the idea of layers and materials as follows.
from most interior of hull bottom to the exterior: 4 layers of wood totaling .62"
layer of okoume 1088, carbon fiber 2x2 twill, okoume 1088, okoume 1088, okoume 1088, carbon fiber/ kevlar hybrid fabric 3K 2x2 dual twill OR carbon fiber/ Spectra hybrid fabric 3K 2x2 twill, outer s-glass sheathing layer.
i took the idea for the placement of the layers and laminate from the book “The Gougeon Brothers on Boat Construction” only they used kevlar on the inner layer and kevlar/ e-glass on the outer layer.
which idea would provide a stiff and long living hull?
any and all information would be most helpful thanks!
