I was recently informed by my supplier that Duratec is now making a UV resistant clear gloss top coat. This is fantastic news!
Now… that one problem has been solved by Duratec… can someone create a chemical that can eliminate pinholes in cured carbon fiber parts? Pinholes are very hard to fill and most clear top coats do not like to penetrate into pinholes found in carbon fiber parts. We do many clear finish carbon fiber parts where our customer demands a perfect or near perfect surface finish - free of pinholes.
If I spray acrylic urethane over a part the pinholes do not go away… they simply pop through the clear layer also.
Can someone formulate a solution to the problem? I’m sure there will be big demand for such a product.
We can’t vacuum infuse everything.
