making the move from bagging to infusion
well ive all the kit for vac bagging and a pump that pulls 29"+ and am considering trying infusion as i cant risk several failures with bagging.
what else will i need? some of the flow media,some tubing and tee’s…is that all?? and some resin with a low viscosity rating? then lots of practise…
I would talk to your resin supplier for resin made for infusion be it VER or Epoxy. You need to consider a resin trap to catch the resin so it does not suck into your pump. When you get the tubing make sure it can handle the pressure and not crush. You would need spiral wrapping so the resin can flow through the laminate
