So after crashing aBMW 2012 GS bike head first into a tree which totalled the headlight and instrument cluster I have been thinking about how I was glad I hadn’t been skewered by the branch.
Now I have the Forcefield chest armour (http://www.forcefieldbodyarmour.com/product/race-lite-chest-protector/2351) which is great for absorbing impact but not preventing penetration of sharp things.
With that in mind I decided to make an over lay for the Forcefield which I could take on and off as required.
Forcefield chest armour.
First of all I measured out the required fabric using my template.
Make sure to protect your very expensive carbon fibre by using masking tape to secure the warp and weft when you cut the bolt.
I will be using three layers this time. Layer one 1 x 200 g/sqm plain weave carbon, Layer 2 1 x 330 g/sqm high modulus tri-axial carbon fibre, Layer three 1 x 200 g/sqm plain weave carbon
The wrap on the mould for the e-glass prototype created a terrible finish which was very resin rich. This time I coated the cardboard with PVA (Polyvinyl alcohol) to allow for an easy release.
To get round it being rather cold in the UK, to help increase the fluidity of the epoxy and to speed cure times I setup a heatgun with temperature sensors.
I then built the layup again with SP systems 106 epoxy and used the heatgun to ensure full wet out. I then squegeed out the excess resin.
the carbon only guard could splinter on impact. please do not see these comments as negative just constructive.
