I have been working with various closed molds and a inflatable bladder. The bladders are currently being made of Stretchlon 800 fused with a iron. The mold is laid up by hand with epoxy resin, mold haves closed and then the bladder is inflated to around 8-10 psi. The parts are coming out fairly well and consistent, since this will be a production part I am wanting to make a more reusable bladder. The SL 800 is a 1-2 time use bladder before it fails or is damaged from removal. I have thought of using rubber sheet and rubber cement to make a reusable bladder, I am looking for input on a good material suited for repetitive use. The part has some detail and is not a straight walled part, so a rigid bladder will not work. The part can be post cured with or without the bladder, depending on how temp sensitive the bladder material is.
Thanks in advance
