[b][i]
I am going to make a fender for this rear swingarm, but I just wanted to ask what would be the best route? I used tape and cardboard to cover the wheel and swingarm. I also sprayed it down with PVA, so the fibreglass wouldn’t get stuck. Should I just layup a couple of layers of bi-directional cloth, then layup up some chopped strand mat over that. Then just continue until it’s thick enough? I was then planning to smooth over with bondo, sand, and skim coat of Q-cells, sand again then spray grey primer, sand, and sand then buff. Then use that as a plug and make a mold off of that then finally make Carbon fibre part. Is this the right way or is there a better way? This is what i’m working on.
[/i][/b]
