Hi all,
I have already made myself a carbon/kevlar gas tank which does the job but isnt perfect. I used standard epoxy resin and coated it with an internal sealant to protect the resin however my race fuel is eating through the protective barrier.
That said, I wanted to try my hand at making another, better model over the coming winter.
So, with that in mind I have a ton of questions and I apologize if a lot of this has been covered elsewhere. I have searched these forums and cannot find these specific answers.
So, I assume that I am to use a Vinyl Ester resin when making a gas tank? It is my understanding that the resin is far more resilient than standard epoxy? Is this correct?
I have a mold that I have painstakingly made and it does the job. I am looking to reuse this mold but I havent used Vinyl Ester before. Are there any particular things that I need to do to protect the mold/facilitate mold release? I have countless hours into this mold and do not want to risk any damage to it.
Finally, am I on the right track with just vacuum bagging vinyl ester? Should I be looking at infusion at this point? I want a high quality part but it must be able to be done in my own garage. I would really apprerciate some guidance here.
Thanks in advance!
