Hello all, new to the forums here and I hope you guys can help me out.
This part, rear diffuser, is attached to the bottom of the rear bumper of a car. It will be very close to the rear exhaust tips. This part is mostly just for cosmetics and will not be very thick, about 1/8" thick.
So the requirements for this part would be:
1)Clear, so the carbon fiber and weave pattern will show through
2)UV Resistant, so that the part will not yellow
3)Low viscosity, because I want to vacuum infuse it
4)Able to withstand up to 250-300F, heat from the exhaust tips
Also, what gel-coat and resin would be suitable for this application? Again, it must be clear and able to withstand the heat from the exhaust tips.
I have been told by sales people that most polyester and vinyl ester based resins and gel coats may not hold up at those temperatures. So maybe I need to look for an epoxy based system?
Thanks all.
You can see in the picture below that it sits quite close. My guess is the temps would be more in the 150-200 range which would open up allot more resin choices. The VE I am using for my hood has a heat distortion temp of 220F and a glass transition temp of 250F.
