Low cure pre peg and curing methods
I was looking low cure prepregs and these are used under normal vacum bagging pressure (29Mhg).
Now i have a decant work area and was hoping if i built a small room big enough for the largest parts i would make that would be the room to cure in
Now here is what i was thinking to use to cure the prepreg, in automotive industry infared lighting is making big noise, the last major bodyshop i was at had a both that fully used infrared curing systems. The inital cost for a booth using that was 40,000 uk pounds. But the cost of a bake was 4 pounds.
You can buy portable infared lights for alot cheaper 200 pounds or so any body on here had the idea of infa red curing
Yep and it works good. Also heat lamps work good too so long as you have a few thermocouples. Infra red can actually be pretty bad ass as it cooks hot and fast. Used the lamps a ton in the military curing epoxy and adhesives. Also used lamps for backside heat and water extractions. They will heat a small room up fast. Don’t burn your house down.
Its not in my house i do have experiance with them in bodyshops when we was priming out of the oven (rapid repair shop where 4 ovens where constantly in use 24 hours aday for paint jobs)
So do you think the infared would be a good option to use
I think it would work… But those things pull alot of electricity… Why not get a used oven?
or build an oven, it’s not that hard, or expensive. Wooden/steel frame, some rockwool and sheat material, heating elements and a fan or two.
At my workplace I have an oven in wich the whole car fits. It can be devided in 2 spaces for smaller parts, I hardly use the whole space. I use a Variable temp. system, I normally cure at 85 degrees celcius, can go as low as 65, or as high as 120.
Also infrared can cure in irregular patterns. It is so easy to burn one spot, and have a cool spot right next to it.
Yep Herman is totally right
Yes im aware of this to but there are lights that when set to the right distance evanly spread the heat
Low temp prepregs can be intially cured at low temps, but usually still require a higher temp post cure. So you would probably be best to construct or buy a oven. Benefit is low cost tooling with low temp prepreg.
Usually it gives a lower surface quality when curing and later postcuring.
if left unsupported, and depends on the resin.
there are low temp prepregs that are designed for excellent surface quality.
If left unsupported, offcourse, but why would you cure at lower temperature then, and not do the full cycle at once?
I use a system wich can cure as low as 65 degrees celcius, I used it for prepreg in a polyester mould. surface quality was ok, Tg and other mechanical property’s where not. After a postcure they where, but there was a printtrough in the surface.
At one of my previous jobs we built a demonstration piece that we would take to Sampe and a few boat builders expos. It was called Boat IN A BOX.
Basically we took a wooden shipping conatiner and lined it with aluminum backed insulation. We would ship everything we needed to set up the booth, 5 foot dingy mold, table, prepreg, cosumables, vacuum pump, heating element, etc. The shipping container was the oven, we used a heated fan that would get the box to 180-200F depending on how far away we placed the fan. It worked great and to my knowledge is still being used today.
Many consumables degrade after a resin cures, and then is post cured. I’ve had parts tossed because the peelply and bagging melted onto the part. if i cured, and rebag, it does not happen. Unless you have an expensive high-temp capable mold, then can’t toss the mold in an oven to cure/post-cure if it can’t handle the post cure.
